Zenec mc5600 installation help please
Hello, I have only recently become an Octavia VRS owner and have replaced the stream MP3 with a Zenec MC5600. All seems Ok apart from two issues that you may be able to help me out with
I need a new surround for the radio, its the climatronic one, but I dont think the one for the MFD 2/3 is the correct one. Can you provide me a part number?
Also when I try and play back a DVD is says that the car is in motion with a blue screen so no picture is displayed.
I weuld appreciate being pointed in the right direction with these two issues
You cannot play DVD's/MPEG's etc on the main screen whilst the car is in motion. From what I remember it is linked to the handbrake and will only operate while the handbrake is applied.
The only way to playback films is to enable the 2nd zone & fit another screen elsewhere in the car.
With regards to the dash surround, the Zenec that I purchased was for the Pre Facelift Climatronic, I'm not sure if the Post Facelift cars need a different surround. With regards to a part number your best bet will be to speak to a Zenec distributor or Zenec themselfs.
Matthew
Matthew
The DVD will not play back even when the car is stationary and the hand brake applied!
hope this help trouble shooting ect
http://www.zenec.com/uploads/media/ZE-MC5600_Manual_D_E_05.pdf
Different disc type has different repeat mode. Please refer to the
table as follows.
Disc type Repeat mode
DVD Repeat Chapter ➞ Repeat Title ➞ Repeat Off
VCD (PBC off) Repeat One ➞ Repeat All ➞ Repeat Off
CD Repeat One ➞ Repeat All ➞ Repeat Off
MP3/WMA Repeat One ➞ Repeat Folder ➞ Repeat All ➞ Repeat Off
MPEG Repeat One ➞ Repeat Folder ➞ Repeat All ➞ Repeat Off
Picture Repeat One ➞ Repeat Folder ➞ Repeat All ➞ Repeat Off
 NOTE:
■ When a VCD is played back, this function is prohibited if the
PBC is on.
■ Turning off the power or switching playing source to other
modes and back will cancel this function.
Repeat A-B
When a DVD, VCD or CD disc is played back, you can play back
the contents between the time points from A to B repeatedly.
Press the [RPT A-B] key on the remote control to set the start point
(A) and do the operation again to set the end point (B) of the section
you want to repeat. Press the [RPTA-B] key for the third time to
cancel the A-B repeat function and normal playback is resumed.
Random playback
When this function is on, the contents in the disc will be played
back randomly.
During playback, press the [RDM] key repeatedly on the remote
control to change random playback mode among random, random
repeat and random off.
Intro playback
When this function is on, the unit will play back the first 10 seconds
of each track of a VCD or CD disc. This function can help you to
find the disired file.
To activate this function, press the [sCN] key on the remote
control.
To cancel this function, repeat the operation above.
Search for a part icular file
When a DVD, VCD or CD disc is played back, you can search for
a particular chapter / track by pressing the numeric keys of the
remote control. For example, if you want to select the 15th track,
you should press the numerical key [1] and [5].
GOTO search
■ Enter the GOTO search and select the search mode. Different
disc type and file format has different search mode
NOTE:
PBC is on.
TROUBLEShooting
DVD player
Symptoms Causes Remedies
Disc cannot be inserted. There is a disc in the unit already. Eject the disc and then insert another one.
Disc cannot be
played back.
Disc is scratched. Change the disc.
Disc is too dirty or wet. Clean the disc.
The pickup is dirty. Clean the pickup with cleaning disc.
Disc is not compatible with the unit. Change the disc.
Parental lock class is too high. Change the parental lock class.
Disc is inserted upside down. Insert the disc correctly.
The disc‘s region code is not the
same as the unit‘s.
Change the disc.
Subtitle can not be shown. There is no subtitle file in the disc. Change another disc containing subtitle files.
Audio/subtitle language
can not be changed.
There is only one audio
language/subtitle in the disc.
Change another disc containing multilanguage
audio or subtitle.
View angle
cannot be
changed.
There is just one view angle
in the disc.
Change another disc containing multi-angle.
Multi-angle view is not available
for the segment playing back now.
Select another segment to play back.
distortion.
The disc is protected by
the copyright.
The unit is compatible with copy system;
hence some discs containing copy
prohibited information cannot be played.
PBC is invalid when playing
back VCD.
The disc does not support PBC. Change another disc with PBC function.
Repeat playback or GOTO
search is invalid when
playing back one VCD.
PBC is on. Close PBC function.
Having tried again - I have discovered that if the ignition is on, and the handbrake is on then teh DVD will play back, as soon as handbrake is released Video goes off - as expected
would be nice to get DVD playback with ignition off!
James
James
Ah, I'd forgotten about the ignition needing to be turned on, I guess this is for the Zenec to realise the handbrake is applied
for info the correct surround is
1Z0858069CG (silver)
