SuperSkoda Grilles
Any of you folks have any experience regarding the upper and lower grilles Superskoda supply?
The Grilles are the 3rd and 4th down in this link
Any experiences/photos much appreciated !
Cheers,
KC
Yeah I got both. The lower grill is okay but the bottom edge especially on the corners doesn't completely adapt or clip onto the bumper properly but isn't too noticeable.
The upper grill is what you'd be worried about. The clips in the factory chrome frame doesn't clip into the honeycomb grill and requires a lot of modification and cutting. Even after a lot of work and after final assembly and fitment onto the car, you'll notice there's huge gaps on the top left and right corners where it doesn't sit flush or as close to the bonnet as the middle section or the factory grill assembly does (not noticeable when looking front on but will see the horrible 3-4mm gap when standing on the side of the car looking down at the margins where the top of the grill frame meets the bonnet. Not so bad if you have a black car but very noticeable with a bright coloured car like my sprint yellow one). As if that's not bad enough, the lower right hand corner (when you stand in front of the car and look at the grill), keeps popping off the brown factory clips that clips onto the bonnet and results in an unsightly gap which requires you to push it back in to help it clip again (need to do this several times a day). Bloody annoying. I'm honestly thinking about changing to the milotec mesh grill (hopefully fitment this time is spot on).
You're a legend!
Thanks for the information.
I'd practically ordered both grilles at 4am this morning when I'd gotten home from work. Glad I opted to check on here first.
You mentioned the milotec mesh. Is that the one from Superskoda?
I take it the face lifted lower grille wouldn't fit the older bumper?
Thank you again for the heads up,
KC
