rear lights?
Changing my nuber plate bulbs for the right one i hit the metal part with my key :giggle:
Now my left (passenger) tail light aint working.. iv've checked it to see if it blown but its not.
so the left tail light dont work or my number plate bulbs.
checked my fuse under the steering wheel nothing broken from what i can tell.
Any one got any ideas?
My money is on the fuse.
Does your front passenger side sidelight work?
yes it works... now its light can a better look
Sent from my GT-I9000 using Tapatalk
ad a proper look now at it dont work but all the fuses are fine
Swap the tail light bulbs over to make doubly sure , and my number plate bulbs if one goes they both go out.Always have them off before you change anything, turn ignition off then on again then try the bulbs, and have you a bulb blown warning light
car does have warning lights
but fuse 17 was broke so changed it and now its fine
except now my air bag light is on
