Sat. Nav. Fitting
When I sold my last car (Vectra V6) I removed the Sat Nav I had in the car with the intention of having it fitted in my new car (vRS WRC).
When I enquired at my local Dealer who fitted the system in the first place I was told I needed a "Speed Pulse Generator" & a new bracket for the remote LCD Screen. (he wanted
There are people who will know better than me, but I know that GALA on the ICE radio setup in Skoda's is a way of the ICE increasing volume automatically as speed increases to compensate for road noise. It can be adjusted to 9 different settings on the Symphony model.
Hope this helps :?
Damo
I'd imagine it does work off speed rather than noise, and as such could be what you're after.
Usual disclaimers apply though... :D
Rob.
Originally posted by robmawer in this post
I'd imagine it does work off speed rather than noise, and as such could be what you're after - it goes to the same volume at
70 whether your cruising over smooth tarmac or bouncing over
concrete...
Rob.
Ah, poo, done it again... :rolleyes:
Rob.
check the old posts on here.. i remember reading that octavias do have a speed pulse signal as std...
Yes I recall reading that too.
My local car audio dealer re-fitted my Panasonic DVD sat nav system into my Octavia and though they initially warned me that I might need a speed pulse adaptor, subsequently found that it is NOT required.
Unfortunately, I don't know location of connexion point, but if you're stuck, I could find out.
John.
You definitely do not need a speed pulse generator
The ISO connector has a speed signal to allow the radio to adjust the volume according to the car's speed.
I have a Clarion NAV613 system fitted in my vRS and I deal with Clarion with my work.
They actually run a VRS and Leon Cupra in their fleet and faxed me a wiring diagram - which I sent to my dealer - saving the
Is GALA Speed controlled or something else (Noise?)
If it is speed controlled this would make sense.
Anyone fitted anything ??
BIG K ?? (Our Resident Expert)
Graham
PS I really miss the electronic "nagging" of my Sat Nav. lady blandly telling me where to get off (the roundabouts!) !!
does this involve a hammer :D on a serious point yes gala is effected by vehicle speed so you should be able to use this.
Thanks Big K !!
(Knew i could rely on you !!)
:cheers:
Graham
big k, you really need to learn how to use the quote button properly :D You're make a right old mess of it all :p
Q.
  • 4 weeks later...
I have Sat Nav in my Occy TDi - The speed pulse for this was taken from the back of the radio (Hence the GALA auto Volume adjustment). I rang up the dealer asked which wire and they rang me back 5 mins. later and told me which one to tap into.
