inst cluster fuses
I have still problems with my inst. cluster. Have had the soldered joints checked at my local electronics shop - no different. Does work occasionally but only for a few seconds. When I had trouble with a leaking rad it would work sometimes ok for the full time of a journey or journeys. Now the leak is sorted (after the 3rd rad) it very rarely works only for a few seconds. I did read that u could try removing a fuse but I have searched the forums without success. must get it sorted asap as its due for mot shortly Can anyone help
Tel
Pulling fuse 15 will get you back some of the dials (I think it's speedo and rev counter)
Might have to bite the bullet and get a second hand cluster
did u solder the resistor joints ? or just the TLE ?
i recommend a close-up inspection of the board, as the soldering is of extreme low quality (a capacitor fell of my board the moment i removed the dials...)
Yes had all the joints were checked by the local electronics engineer who recognised it straight away as being Skoda.Ithen bought a used cluster which then needed setting up to the ecu. & when I asked Skoda the cost it was going to be more than the cars worth so tomorrow is D Day when I try this fuse
Thanks Again
Tel
the new cluster only needs immobilizer adaptation. this can be done by anyone with vag-com.
a second thing the dealer would to is set the total traveled miles to match the old cluster.
imo neither of these tasks deserve a main dealer visit...
Bingo fuse 15 did the trick. U have no idea how pleasedI am for your help in sorting this SWMBO was threatning me with a NEW LIME GREEN Hyundi. Had a few drinks to celebrate nipping that in the bud!
Thanks once again for your help
Tel :D
Glad it's sorted, pulling fuse 15 is only a temporary solution though but should buy you a bit of time and get it through MOT then see if you can find someone local with Vag-Com to help you get the replacement cluster working with your car.
