My THS Intercooler
eerm doens t the pancake pipe catch on the ARB links? might wanna check it every so often? Mark fitted a larger one and went back to std as they rubbed, the std mk4 links would be fine tho as they go to the wishbone not the strut.
Looks good tho.
true Billy it did...
Load of room. Would never bang the arb ever
It would if you run car as low as mine as the extra size of the pancake rubs on the antiroll drop link bolt. You won't notice this if the car is jacked up as that is not how it will sit on the road. Bend down and take a look as the car is sitting on the road. It will be closer than you think if car is low. I almost went straight through mine. Shame as the larger pipe did make a slight difference
They must of changed the design as its not near and I'm low. Running 17 with 205-45 tyres and it grounds out on most things. It needs to be raised if anything.
  • 2 years later...
I GOT THIS KIT THE STAINLESS HOSE TO THROTTLE BODY ISNT TALL ENOUGH???????????? ANY ADVICE
Chop the bar that runs through the bumper bar iirc 8 spot welds then it just comes out. A small section of the bumper needs to be cut for the bottom pipe and thats it.
PICS HELP PLEASE
PICS HELP PLEASE
It is tall enough just the wrong angle it does go took me about an hour to get mine lined up all good still not to happy with it but it works well
extended 40mm so hopefully all good
