Auto gearbox oil change
Does anyone know how to go about this?
Looking at a 2004 elegance with 155k on the clock and being an auto I figure the box will need doing, I know these boxes are supposed to be sealed and good for life, but in my experience they can always benefit from new oil.
So a few questions.
How is it done?
What sort of oil is needed?
I'll check the oil when I check the car, but need to know what colour it should be, Normally on auto's that I've owned it's a reddish colour, and if it's too dark or smells burnt then the oil needs doing ASAP. Can I assume the same is true of the Superb?
You need the correct gear oil from Skoda, I'd also change the filter which means you need a new pan gasket.
Also you need filling equipment as it gets filled through the drain hole and diagnostic equipment to read the gearbox oil temp to set the level correctly.
  • 4 weeks later...
