octavia vrs head unit
Hi
Ive got the standard head unit/cd changer in my car ( 03 VRS )connected to a parrot 3100. i want to fit my sony cdx-GT50OUI, but the 3 plugs from the stock radio dont fit the sony head unit ( this has only one plug ) so my question is what do i need to buy and where from ????, any help appreciated, thanks..
Edited by niro06
You can get a harness from halfords, you may need to swap the perminent and ignition feeds though, also you wont be able to use the cd changer
Thanks, got the harness now and will have a go fitting after work! i see there are only 2 plugs on the harness but 3 from the loom, i guess one of these is for the cd changer which i wont be able to use any more, will it be obvious which two i need to use and which is the changer one that i suppose just gets stuffed behind the head unit? it was bloody tight for space before i hope theres room for 2 extra plugs !!!!!!
From memory the retaining clips on the plugs are offset, so they will only plug in to the correct one. Its obvious when you see it
thanks for the replies, all fitted and working now :-)
