diadnostics
Please does anyone have advice on the best place to have front windows checked on a 2005 fabia vrs,that work for short time after fuses removed then stop again untill fuses removed and replaced,assume cant be either motor as ok when they work so thinking it must be comfort unit,so what code scanner will check this or best place to take to iemain dealer or auto spark thanks in advance of answers
It's almost certainly the plug in module on the top of the drivers side motor that is at fault. You don't see this particular fault very often but always seems to happen on the 2005 fabia vrs.
Hi thanks for the info is this module replacable or does the whole motor have to be changed
