Rite-o its arrived
Eeek my strut brace has arrived, which means i have to fit it ............ Or pay a garage to do it :(
Is there anything hard anout doing it or anything to watch out for that i could break :(
Im thinking put in place
Mark holes
LOL shut bonnet and check its clear
Take off
Slowly and while ****ting myself drill holes
Put back on and put bolts in
Jack up and try get nuts and washers on??
Adjust so its tight but not bowing
Seems easy in my head..... Which must mean im forgetting sumin
Im planning to paint the drilled holes too so not left bare metel
Mark holes
Take off
My mate and I used a punch to mark the centre of the marked hole, then used a small drill bit to make initial hole then then the bigger one for the final hole.
Measure twice drill once,
It is easy if not a little daunting drilling holes in your strut tops,
place the brace in place and centre punch and then go through with a small drill bit to start with as said above,
Just make sure you rust proof or pain where you drill as been on strut tower its quiet open on inside of strut tower,
When i did mine i tried to weld nuts onto bottom of strut tower to try and make it easier if i ever wanted to take it off but i gave up in end as nuts i got didn't weld very well and trying to clean surface up enough inside tower was a complete pain
whats the strut brace off mate and good luck with this pics after u have done it
Fit it with wheels of the ground ;-)
Buy new drill bits :)
