fault code help
i had my car plugged in the other day and bought up this fault code
17608 - Boost Pressure Control Valve (N249)
P1200 - 35-10 - Mechanical Malfunction - Intermittent
does anyone have any idea what could be causing this? i have also removed my n249 already.
You might have to put a resistor in the multiplug that used to go to the N249 as it's trying to make the N249 work when it's not there. Or you can get a tuner to map it out.
