Would this be a straight swap for Bolero ?
Anyone ?
Hi
Personally I haven't seen that model before. The Columbus unit. I believe you are referring to is different from the one in your post. original Bluetooth is also a separate unit.
I had the Columbus retrofitted and this had to be coded to the can so that the CAN new it was there and. Everything worked trough it
I am no expert but would suggest you check the Above out before parting with your cash
Bernie
Yep, as far as it reads this unit does it all in one, seems a good alternative to a columbus from the way it reads ...
No idea who makes it, it doesn't have the price tag of the genuine vag ones, but its worded like it is !
