Brake discs for Fabia vRS
What brake discs would be a good upgrade fo the basic front discs ? I have a rock chip between the pad and the disc so i could do the upgrade at the same time...
tbh upgrading discs will give very littlke benefit unless
a- they are larger
b-they are lighter
id stick to normal discs unlesds your going for a larger upgrade such as the 312mm conversion.
pads will make a big difference though
Thats a good buy. Still need the caliper carriers though
edit-cancel that. Just read the text and the carriers are included. That is a bargain
Is that a bolt on kit ?
yep. Straight from a Mk4 Golf Anniversary/mk1 Octavia vRS etc
Same seller does green calipers too
Tempted
Tempted
Meant red
Well worth it, had the same kit on my Ibiza (same front brake set up as the Fabia vRS)
Is this kit a direct swap for the existing Mk2 VRS setup ?
Nothing worse than getting a 'so called' kit, then finding out that you need new bolts, screws, hoses etc.
Has anyone actually fitted this to thier car ?
Sy you mentioned pads making a difference, what pads did you go for. I have been looking at green stuff but i am very inexperienced in pad upgrading and have no idea.
Yes and yes
Havent done my pads on this car yet as the whole brake setup is being done so it would have been a waste of money.
Used a few on my last car though.
Tarox Strada = worse than OEM
Mintex M144 = Couldnt fault these, ahndled trackwork with no issues
Ferrodo DS2500 = great for fast road/light track, but melt and spit everywhere when you get them really hot.
My new brakes will be having the DS3000 pads in
Does Fabia MK1 vRS discs fit directly to MK2 vRS ? I have been looking for discs to MK2 but no matches yet.
