Hazards going crazy when I turn Fog lights on!
Hi,
When I pull the main headlights dial, to switch on the fog lamps (front or back), my hazards start flashing like crazy, and can only be de-activated by turning off the ignition and then re-starting the car.
Is this some sort of 'short' to do with the alarm? .........
Any help or advice on this will be gratefully received. :)
Cheers.
Not quite heard of this problem before. Do the hazard lights actually flash externally - have you visually checked? or does the hazard relay chatter violently and maybe the lights comes on the dash?
If the latter I would suggest a blast of switch cleaner into the indicator stalk and give it a good wiggle up/down/forwards/backwards.
Hi mate, thanks ......... I was assuming it was the external hazzards to; but I've just checked and you're spot on; it's actually just the internal hazzard relay 'clicker' along with the green dash arrow lights.
Cool, will give your suggestion a go, and also try cleaning up the Hazard switch relay.
Cheers.
