Faulty Climatronic Unit ?
Hi
Any help appreciated
My daughter has a 2004 L&K Estate. The Climatronic unit appears to be faulty. A couple of weeks ago, none of the buttons would work and it is stuck on 19degrees.
Called in to our local Skoda dealer, described the problem and was advised that it probably needed a replacement unit. The unit alone was around £60. They didn't actually see the car.
Is there likely to be a cheaper solution
Thanks in advance
Only £60!? You can get them off of ebay for that. I would've thought Skoda would charge closer to £200 for a new Climatronic!
I should have proof read the post !!! What they actually quoted was £600 !! and that was just for the unit not fitting it :-(
I got oné just taken out my ?ar as not needed in a track ?ar ;-)
50 deliverd
