Bluetooth 5K0 035 730D audio streaming
Hi all,
Just fitted the above kit and coded. All is working fine with the exception of the 'BT_Audio' option on the Media section of the Bolero. I believe this is A2DP. I haven't been able to find out if my module actually supports it.
Does anyone know if the Bolero uses A2DP for the 'BT_Audio' option and if my module supports A2DP?
Thanks,
Dan
Yes, but the sound may come out MONO on the drivers side only, if your "D" unit is an upgrade from an older "B" unit with older factory fitted wiring harness.
If your new "D" unit came with a wiring harness and you fitted it, you should get STEREO A2DP
I fitted it myself over the weekend with the plug n play writing loom.
What do I need to do to get the option on the Bolero to activate, it's greyed out currently.
Do you have a maxidot display ?
Have you paired up phone as well as Music player (forget exact phrase) devices ?
You should get 2 icons on the maxidot to show phone & mplayer connected.
Then in Bolero, media mode, BT Audio should come out of greyed and a little while and you can select it.
Although in Mono, my HTC One X works as a media player in A2DP mode, and even Google Maps Nav voice comes out over BT, phone handset is silent,
Ah, no I haven't paired any music device. I assume that'll be in the audio section of the Maxidot?
