Which bluetooth?
I've tried searching but not managed to come up with an answer so far. Basically, I want to fit an OEM bluetooth but don't know which one to buy as there are so many different unit numbers. I have a pre-fl 58 vrs with maxidot and a retrofitted columbus.
Can anyone help with the correct model numbers required
Andy
give ben at shark performance a call he will be able to tell you.
Ray
I have the 5N0035730D unit - it does all the different bluetooth connections i.e. RSAP or non RSAP so is compatible with most if not all phones
I've ordered a fiscon basic plus instead, little more expensive than oem but should be just as easy to fit and code
fiscon came today and took less than 20mins to fit. More than pleased with the result, full integration with the maxidot and columbus plus boost pressure and water temp on maxidot :D
