two pins
need a little help guys whats these two little pins for? :confused:
4174.attach
IIRC on top block you have identified....
Top pin is pin 7 telephone input TEL +
Bottom is pin 12 telephone input TEL -
Pin 2 bottom plug left bottom row pin is telephone mute
John
John
Aha! Do you have any information on how to wire up a mobile to this? It would be more comfortable than having my Bluetooth receiver in my lughole all the time.
a ok i thought it was for a sub output or something :( or is there a subwoofer conection kit?
more likely to be steering wheel mounted controls than tel.mute as that is normally integrated into the "power block"
or some thing to with a changer if the stereo supports it
If the pins are what I suspect they should tie up from connections from the appropriate phone kit, never connected one myself
Connect the wires that would normally go to the speaker on the hands-free kit to these wires and the "mute" wire the the "mute" pin on the radio (usually Yellow) works great.
John
Do it the easy way. www.dashmount.co.uk do an adaper kit which just plugs in between the car's loom and the radio and uses the front car speakers.
thanks guys :)
