Info on the VRS I am purchasing
Morning all.
I am picking up my VRS on Saturday. It was registered September last year.
Petrol Hatch in Race Blue, has the Bolero stereo, front rear parking sensors and full sized spare. Don;t think there is anything else that isn't the standard spec.
So is that what is known as a FL Octavia II ?
Being registered last September is it likely to have the revised DV installed from the factory ?
Looking at probably retro fitting the Sat Nav and I'd like to add Bluetooth which I assume I should be able to add the VW module to the Sat Nav once installed.
I'd also like to install a MFSW but Skoda for some odd reason only have that as an option with DSG, seems a very odd restriction to me, can other models be used ?
My old A3 has Xenons so I suspect upgraded bulbs will also be on my list, as will be wrapping the chrome on the front grill.
Any info gratefully received.
Thanks.
Paul
Yes, its a FL (facelifted) octavia II, also known as the Tsi (vs. the older pre-FL which has the TFSI (BWA) engine) which skoda also refer to as CCZA. It's also a 1Z model if that helps.. oh and the newer engine is EA888 like a mk6 Golf GTI where the older pre-FL cars have the same engine as a mk5 Gti which is EA113 (which lives on in the scirocco R and golf R and golf ED35).
My 2010 FL didn't come with the latest "d" type diverter but an swap is only about 40 quid. The part numbers are on here somewhere if you search.
MF wheel - yep, dealer can't help. http://www.skodateile.cz/ has a FL vRS MF wheel without paddles. I'm going to order one for my next car..
HTH.
Diverter valve thread is here incl part numbers: http://www.briskoda....lve-fail-p0299/
btw - i used to have a jazz blue gti many moons ago..a mk3 colour concept. lovely seats, no performance though.
I had a mk4 GTi 1.8T (1999) in Jazz Blue a few moons ago hence the handle :yes:
Thanks BTW
Edited by Gti Jazz Blue
