steering knock?
help please
53 plate vrs is playing up lol the steering makes a cracking noise when i lock from side to side and sometimes when i put it in reverse after driving forward changed strut mounts, strut bearings, springs, shocks, anti roll bars, links, s3 rear wishbone bushes and a drivers side inner tie rod all done over the past few months and no change???????
any ideas
might be the column? or the rack if all else is changed.
are you sure the drive shafts are not catching on something? what about the ARB bushes? is the ARB moving?
Track rod ends? That's what cured mine
Sent from my Galaxy S2 not a Crapple!
you might actually find its brake pads, mine crack and clunk when changing from forward to reverse and lock to lock. The pads have maybe a tiny gap where they are retained in the caliper, If it is this its fine and nothing to worry about.
track rod ends done, track rod rh done, strut mounts done, mount bearings done, as were lower ball joints new eibach anti roll bars with new bushes and links with new h and r springs and koni sports shocks and wish bone rear bushes, dog bone mount gear box mount exhaust hangers still knock can feel it through feet and wheel?
