electrical fault
sometimes, usually when switching off the car the instrument panel clock and the one on the radio resets, the radio loses all its memory so appears to be a complete power loss. anyone experienced a similar issue, I have a good understanding of general electrics but not specifically the electrics of this car, and I don't have much money I can throw at it anymore,
thanks in advance
Andy
well you will be happy to know its a popped fuse, have a look through them. Common issue, seen it on polos golfs and a passat
after this it may be a low voltage issue, battery would need replaced
Edited by Lofty79
Fuse 15 - should be 10A
fuse is ok, fault is intermittant only happens now and then and battery is fine was changed not long back and car starts fine
loose connection to back of offending items then?
Intermittent battery fault, start at the beginning, taking things off and back on. Battery cables, fuses and cables on top of the battery, and earthing cables.
Try them first and see if it makes a difference
Sent from my Galaxy S2 not a Crapple!
If you don't have any problems with the engine, then check that the terminals on the bottom of the relay plate are tight. Check the earth point to the left of the relay plate. It should have a chromed, domed nut and will have brown wires running to it.
http://www.briskoda....attach_id=22927
I removed this fuse and found it doesn't affect the radio, only the instrument panel,
ill have checked visually most of the wiring ill have another look round soon and report back, thanks for all your advice guys much appreciated
Andy
