Fault codes, MAP sensor, Advice Please
Ran for codes today, just for the heck of it and it threw this up! Is it possible that this could be needing replaced? car runs fine, so didnt expect to get anything.
what are your reconings? Heres the codes. Anything else that can cause this reading?
VCDS-Lite Version: Release 1.1
Wednesday, 25 July 2012, 15:26:55.
Chassis Type: 1U - Skoda Octavia I
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,56,76
Address 01: Engine Labels: 038-906-012-AGR.LBL
Controller: 038 906 012 H
Component: 1,9l R4 EDC 0000SG 3332
Coding: 00002
Shop #: WSC 31480
VCID: 155D42577C8F
TMBCG41U332748395 SKZ7Z0B1716454
1 Fault Found:
17563 - Manifold Pressure Sensor (G71): Short to Plus
P1155 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.LBL
Controller: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 31480
VCID: 33199CCF123B
No fault code found.
Tried deleting it and seeing if it comes back? My octy had a few codes when I brought it but apart from the cam sensor coming on now and then nowt has come back
Sent from my Galaxy S2 not a Crapple!
yup cleared and came back, did it thrice. Could be it wants changing
bump for opinion, should i change my MAP sensor?
make sure it is plugged in properly failing that unclip clean and econnect then clear codes
hth
ok cool cheers
