Roll bar info
Hi guys,
I've found my knocking eventually, roll bar bushings!
I read a bit about them, but now I'm confused as to which ones I need! Also whats the sleeve does this come with all bushes?
2005 mk1 octavia
James
From what I understand the later octys didn't have the sleeves, which is just a plastic collar around the roll bar, so I would be surprised if yours have them. In any case if you get the smaller sized bush and it turns out that yours does just take the sleeve off as it causes more trouble than its worth lol
Sent from my Galaxy S2 not a Crapple!
My 2003 did have them, if it helps...
Of course the problem is, you haven't told us what model Octavia you have...
Duh just presumed a vrs lol. think it was around 04 they stopped fitting them
19mm bar on the vRS (without sleeve).
Steve.
my 05. vrs had the none sleeve type.
