Xenon Headlight Adjustment
Anyone know if it's possible to adjust the beam on the Superb's Xenon headlight, I know they're auto levelling but there is usually still a thing on the rear of the headlight to adjust them. Is this the case with the Superb. As my beam is too low. Thanks.
Not sure of Superb, however you can open the Bonnet and look for adjustment screws on the Headlight placed towards the Grill, as is the case with my Octavia II Xenons:
http://www.briskoda....t/#entry2867280
I believe the correct procedure is to set the lights into an "alignment mode" firstly via the diagnostics port, and then they are aligned using the screws.
There is another possibility I guess - that the self-levelling feature isn't working. If you turn your lights on before starting the car, and then start the car via the ignition, you will see them (hopefully) move through a sequence of dipping fully and then raising fully. It might be that one of your lights is stuck dipped.
The self-levelling feature is a requirement for MOT (along with the headlamp washer system) - due to the XENON lighting.
It could also have been put into tourist mode for a trip to the continent and left like it - this flattens the UK passenger side instead of it kicking up - I'm not sure how that is changed though.
Hmm I'll have a look. I'm familiar with the auto leveling. When you start the engine, the headlight unit dips and then raises. But when you turn the lights on it stays there.
However it was plugged into VAG COM last night and it said there were no faults.
Sent from my iPhone using klatapaT.
Which is good news and only means you are all set to turn the screws and adjust the level.
Coolio :) So it does have screws to turn. I'll go have a fiddle now. Thanks!
Any idea where the adjustment screws are, I can't see anything :/
They will need to be set into adjustment mode before you can set them.
Oh poo.
Where's the best place to get that done?
Anywhere with VCDS or dealer diagnostic equipment.
Getting access to VAGcom tonight but the rear of the headlights look extremely difficult to get to!
For adjustment you don't need to get into the headlamp, there are holes in the lock carrier to get to the adjustment screws. And of course they should be set up on a beam setter.
There will be a beam set up thingy at my Cousin's garage. However he doesn't deal with this side of the car mechanics so if I want it doing for me I'll have to pay the guy that does.
Just wondering if the screws are obvious and it's easy for me to do.
Yes they are pretty obvious and in the owners manual iirc.
Thanks for the help everyone. It turns out that my passenger side Xenon has an "Error" :sweat:
This happens when someone adjust the headlamp without it in basic settings and fudges the motor adjustment.
Am I best taking it to a Skoda Dealership to sort out?
