steel wheels
hi guys will mki octavia 16s steel wheels fit a roomster if so how cheap thanks pete
Cheap? They fetch more than alloys lol. Think a roomster is 5x100 so will fit with different tires from the octy
Sent from my Galaxy S2 not a Crapple!
hi raf ive got sum 16s off the rommy as new was going to use the tyres whih are 205 45 16s and put them on the octy wheel
with new wheel hub caps and chrome wheel trims make it look like retro look if i can get a set of wheels
Octys are 205/55/16, 205/45/16 will knock your speedo out by almost 5mph at an indicated 70 = (65.38). It's dead on the recommended +or-2.5%.
Personally I wouldn't put those tyres on m8, will increase your mpg if you drive at true speed and also increase the wear and tear of the car as the running gear will be going further as will the dash milage
Pete, hope you're well.
It depends what you're currently running.
My Scout runs 205/40/17 with a steel spare running 205/45/16.
They are both 5x100. In answer to your original question, yes the rims will fit, but you may need different tyres.
