Silicone Pipes - HELP
Hi Peeps,
Just a quick hand if you could?
I have deleted my N112, N249 and Secondary Air Pump from the car, I'm also going to carry out the Evap and Vacuum lines simplification along with fitting an oil Catch Tank.
I would like to fit a DV relocation kit but my question is what are the actual pipes needed if i was to buy seperate?
I.e N75 Pipe
Intercooler to pancake pipe
DV relocation pipe ETC...
Thanks for the help!
Adz
Hi you may be best to Speak to Gee@ W8 performance. He has just completed the task that you are after doing and can supply you with all the pipe work required.
Adz i will send you a price tomoz as per your pm
Will get you a good price and availability
Next month i will have a large stock of creations hoses ;-)
Coolio Gentlemen I shall be sending some PM's : )
