Uneven coilies
I think ive just measured up that my rear passanger side sits 5-6mm lower than the rear drivers
And the front passangers sit about 3mm higher than the front drivers
Theyve always been wound down the same amout ?? :(
Would it work just winding the slightly higher corners down ?
Hmmmm ? Seems to easy
What are you measuring, and where are you measuring from ?
The 6 mm is from the garage floor, i was trying to go from center if the rim
Its def down as i resorted to childish poking and rear passanger bites my fingers unlike the rear driver that is abit more friendly and lets u put them under the arch :(
Passenger side front higher than drivers side front. Sounds like its a case of variables acting upon car, are you a food fan?
You need to check the length of threads of the coilovers themselves
measure with ruler to be certain of heights and whether you've got any spring seating issues (typically at the back)
I doubt your garage floor is completely level
What would spring seating issues be ? Like not sat on the adjuster rite or something ?
The front 2 are not really much different... It really is the case Of the back
The front passanger has had a new insert too
Sometimes the rear springs and get slightly unseated, basically not sitting on the cup right
Typically happens when jacking both wheels off ground, and then lowering a bit too quick
Gently jacking and lowering normally enough to sort
Might not be, but worth checking before adjusting coilovers :thumbup:
My right side is lower than the left side (driver) with same 5-6 mm ,and I'm a big chap.
Standard suspension
Edited by IulianE
lol they would be different heights, each corner of the car will be a different weight
Sent from my Galaxy S2 not a Crapple!
Its my passangers side rear thats higher lol id blame dominos if not
That spring thing mite be worth peeking at, as if i jack it both wheels get off the ground.... I will peek in the morning :) fingers crossed
All coilies are the same adjust them evenly so they match
Exactly they are the same but the weight of the car differs corner to corner so setting them all at the same height will make the heights different lol
Cheers mate, i'll have a crawl under him and check springs
Then measure threads
Then just play with the height :)
They'll need corner weighting to be set bang on :)
As raf says each corner will weigh different, although I've always set mine by sight tbh.
Ok... The sun is coming up.....
Springs are sat fine
Rear drivers would 2 turns..... Well maybe 1 and 3/4 as my marker was not facing :D
Mesurement match now on both rears on the most levelish ground i can find.... Tried to measure thread above and below but couldnt see exactly but nye the same
Its looking a liitle like maybe one wheel sits slightly further out :D or i could be still asleep
Im asuming the axels srnt offset to ask a daft question ?
Either way st the mo both arches bite my knuckle on the same point ;) technical measuring i know but hey lol
