Replacing Aircon Condenser / How to put Lock Carrier in Service Position
Finally I’ve managed to find the time and, more importantly, the money to get my air conditioning working again. I’ll put my experiences of the fault finding and repair in another post, however, I thought it may be useful to post separately the process I used to change the condenser. These are my experiences that I share with you – I am not a mechanic and do not provide this information in anyway as an approved maintenance instruction.
I have a 2005 1.9 TDi and whilst it is necessary to remove most of the front end of the car to replace the condenser, you do not have to drain the car’s coolant system (I believe this is required for FSI engines). I will describe how I managed to get the Lock Carrier into the Service Position, and then replaced the condenser. The basic process is remove headlights, then bumper, mark body work positions, release lock carrier, pull forward lock carrier, release radiator assembly and remove condenser. My aircon system was empty (hence the repair) but otherwise the gas would need evacuating by an authorised person.
Your will need Torx bits T25/T30/T45, and a M8 Spline bit. You will also need to source min 4 and max 8 M10 bolts of approx 120mm length. I used 4 x M10x120mm bolts (normal thread not fine engineering thread) that only had the thread on the last 30mm. This meant that I could tighten them into the bottom lock carrier screw threads and the lock carrier would then run easily over the unthreaded section.
To remove the headlights, open the bonnet and remove the white nylon threaded fastener that is located just on the top inboard side of the bulkhead each side of the car. These can be removed with the fingers. You then need to locate the metal hockey stick shaped lever that sits on top of the bumper and below the headlight on the inboard edge of the unit. This lever needs to be pulled towards the centreline of the car (towards the other headlight). Mine were stiff and I used the shaft of a screwdriver rather than my finger. As you move the lever the headlight will release and can then be pulled forward. Slide the headlight forwards out of the housing and detach the wiring loom. Nothing that you have done impacts on headlight alignment assuming you re-assemble it correctly.
The bumper removal is actually quite easy if you tackle it methodically. Remove the 2 plastic trim panels at the bottom of the bumper inboard of the fog lights. These pull out with care to reveal a couple of torx (T25) screws. Next, move up to the top edge of the bumper in the area where the headlights have been removed. You will see that there are 2 plastic expanding rivets each side. These are fairly easy to remove by placing a flat edge under the centre plastic peg and slowly levering out the pin. The main fixing then removes easily. Whilst you have the technique and the selected tool in your hand, move down underneath the front edge of the bumper and remove the 3 plastic expanding rivets that sit in the centre section. Whilst down there you can remove the torx(T25) screws (2 each side) outboard of the expanding rivets. I suggest you now deal with the fixings inside the wheel arches. You may need to turn the steering to provide more room at the front of the wheel arch. You have to remove the 3 torx (T25) screws at the bottom, front, outside edge of the wheel arch. Once you have taken all 3 out you need to lift the bottom edge of the upper wheel arch cover to find the last remaining torx (T25) screw. This is hidden on the rear face of the bumper assembly about 10 cm front the top and about 5 cm forward of the wheel arch. The screw actually compresses a spring clip and one of mine popped off anyway whilst I was searching for it. All you have to do now is to remove the obvious 5 bolts on the top (T30) and front face (T25). When you pull forward the bumper remember to pull off the headlight washer covers (these pop off), the washer nozzles (or hoses) and disconnect the fog lights.
With the bumper removed the left and right plastic bumper carriers come next. These are just below the headlight area and are each fixed with 2 screws.
To ensure that I did not have any alignment problems on assembly I marked all of the key panel mating points with tippex. There are 4 big bolts each side holding the main bumper reinforcement to the front chassis (these are the ones you will replace): I marked this panel for left/right and up/down alignment. I also marked the inboard top of each wing section above the inboard edge of the headlight section. One not to forget is the single bolt each side of the car on the lower headlight section (to minimise risk of headlight alignment changes).
I took out the air intake box at the top right of the front section but you only have to disconnect the air hose. You do this by lifting the top panel of the box to allow the pipe to be released. Next release the bonnet opening cable by finding the plastic connecting box (about 1 cm in diameter and 10 cm long about 20cm from the bonnet catch. When you lift the cover on this connector you will see then the cable separates easily. At the same time disconnect the alarm wire in the same location. This is where you drain the coolant and separate the top hose for some engines (FSI?)
Almost there! Remove the spline (M8) bolts each side of the panel containing the bonnet latch. Remove the 8 spline(M8) bolts that hold the main cross member on to the chassis. I took the bottom ones out first and replaced them with the long M10 bolts. Finally remove the bolt each side of the section at the lower rear of the headlight void.
The only thing now preventing you pulling forward the lock carrier is the aircon pipework to the condenser. Place some form of fluid catcher (even if only newspaper) under these pipes before undoing them because they contain some coolant oil. The flange is secured with torx (T45) bolts and once removed it is difficult to separate: be patient to avoid damaging the mating surfaces. The condenser holds about 10cl of coolant oil so handle it carefully to avoid spillages. Once the coolant pipes are separated you can pull forward the entire assembly. Stand back and panic about how an earth you are going to get it all back together! I was at about the hour and a half point by now.
Before releasing the 4 radiator (T30) screws (2 on each side of the frame assembly) to permit access to the condenser, I took the weight of the radiator onto the upper frame panels by looping a chain of plastic cable ties together around the coolant pipes on the top radiator face and through the upper holes in the car body work that were secured with M8 spline bolts to locate the front lock carrier. It wasn’t pretty but it did the job. I then removed the 4 radiator screws and then the further 4 (T30) screws holding the condenser to the radiator’s front face. It was a bit of a juggle to extract the condenser and an extra set of hands would be of great use. I was glad I put a plastic bag over the end of the coolant pipes to prevent the oil spilling out of the condenser.
As they say in all good manuals; refitting is simply the reverse of the process. I did not replace the o rings because I couldn’t find the size required (not in all “common items packs” I looked at). You must also remember to get your aircon tech to add more oil to the system when he re-gasses it (the book says about 10% of the total volume for your system). There is a total of 110cm3 (plus or minus 10cm3) in a Sanden compressor system. Using the alignment markings that I made I had no problem getting everything back with good panel fit and without any impact on headlight alignment. In total it took me just over 2 hours 30 mins and saved me a £200 labour charge.
  • 3 years later...
Thanks Navman, just putting my bumper back on after following your guide :)
My condenser and intercooler both needed replacing
