The pipe thingy!
Some genuis may have just snapped the end off the pipe which connects to the Y shaped breather hose (nearer front of engine bay). What pipe is this? How much? And how difficult is it to fit?
Tried having a gander where it went but couldnt see the other end and it was all under the throttle body housing...
I've got one to fit but hurt my back so can't do it lol
Need hose clips and lil hands lol
Sent from my Galaxy S2 not a Crapple!
thanks for the recommendation Raf. Drop me a PM muppje fella and we can sort you out. :thumbup:
lol thought you were off this week m8.
im supposed to be but i cannot keep away! lol
Next question is how do you remove the standard retarded hose clips? Without hacking them off :/
Trying to fit the other breather hose (dont know what pipe it replaces), TIP, and dump valve but these clips are everywhere and cant get them off!!
How does TIP attach at bottom? Cos i couldnt seem to see a clip like normal?
you need to replace all the standard clips with Jubliee clips (bar the one at the top of the TIP - but I would also replace that while you're at it)
the factory clips can be a bit of a pain to remove, I removed them by putting a flat head screwdriver underneath the end and twisting it to pop them up and then pull them out with a snipe nose pliers
the bottom end of the TIP (if you're rplacing it with a silicone TIP) should also be attached with a jubliee clip
see here for a nice guide on how to install:
http://www.google.ie/url?sa=t&rct=j&q=installing%20tip%20golf%20mk4&source=web&cd=1&cad=rja&ved=0CEYQFjAA&url=http%3A%2F%2Fwww.billswebspace.com%2FOVDMk4ForgeTurboInletPipe(TIP)Installation.pdf&ei=Q5MuULjdHcqphAfFtIHIDA&usg=AFQjCNGlb1hamX_gfARpTuf3CpejJTKZHA
