Rear camber shims.
I'm thinking of maybe getting some for the rear of my car. Bit of negative camber. Venom motorsport list some Eibach camber shims for the Octavia VRS mk1, would I be right in saying they will fit my Fabia all ok?
there the same wheel fitment,but are the hubs and axles the same?. . coz they go behind the hub dontt they?. .
do you need the rear camber that much?. . im running 8.5j on back of mine,coil adjusters out with no problem and stood behind it,it looks quite cambered already,they have -1.5deg as standard i think.
Yeah I know they are the same wheel fitment as im running spiders, but was unsure on the hub side of things?
I only want a little bit of camber, ones listed iv seen are -0.5 or -1.0 I'd prob go for the -1.0 to be fair. If it don't look great it's not the end of the world they are cheap enough.
have you got em spaced out?
coz you won't realy see it otherwise,only really see it when you have wheel lip poking out the arch.
I'm currently eyeing up some 20mm rear spacers to try out on the rear of my car, hopefully they won't poke out too much, trial and error really.
Cheers for the link bud. Much appreciated.
don't need to be trial and error, just alot of working out and measuring up haha. . like find ur spiders et . . and deduct 20 for 20mm spacers.
my rears are 8.5 et25. n and I've fitted 10mm spacers before. . so that's et15 . . lots of poke haha but i run a big stretch on the tire.
17" Spiders are ET38 so minus 20 for the 20mm spacers equals ET18 which is a tad low. But I'm not mega low just on Eibachs.
Def don't want them catching my arches, as on my old mk3 Ibiza I ran 20mm rear spacers and used to catch, couldn't have people in the back, so stripped it all out lol.
I want my Fabia to still be useable for passengers.
Put a washer on on bottom of the hubs but also don't forget to back caliber carriers as well
I trust metal more then plastic
  • 2 months later...
A few months old but what ones fit the fabia. Please help
eibach do some ant. . i think there listed for polo tho. . .
Mk4 golf versions are the ones to get I think. Still haven't ordered mine yet but will do before long. Venom motorsport sell the Eibach versions. Hope this helps.
I've seen some mk4 golfs etc and polos buy which mk? 5 or 6
