How to change alarm sensitivity in vagcom settings
As title please reckon that's the cause of my sleep deprived nights...!!!
A good friend of mine has v.com but isn't sure how to adjust the above after a brief search I see most cars from factory are set on 100% most seem to drop to 70 or 50
Cheers in advance to all whom reply....
Pete.
Sensitivity coding will be held in Module 46, Central convenience. I've never had to adjust it though.
The settings for sensitivity may well be contained within the Innenraumueberw 'sub controller' which I'm lead to believe is for the internal alarm monitoring and sensing. But I'd have to check that on my own car for you, to be 100% sure.
For accessing the sub-controller you need to open Module 46, then select it from the drop-down menu at the top of the VCDS screen.
Thanks Wardy gonna get my friend to have a look soon as he gets chance
If I get chance I'll check on mine for you and post up some more info.
