Octavia mrk 2 facia covers.
Ok hear goes,I took out the standard double din and put in a Sony which went in great but when I put the facia back on,the one that covers from the ash tray up to the stereo and around the heaters I found the adaptor I used to install the single din is to narrow on the sides.im not explaining very well sorry but the screws which held the original stereo are now showing so I'm needing a bigger adaptor on the sides.hope someone understands what I mean and can point me in the right direction.just remembered I bought the kit from a company in Paignton called ice if this helps,cheers Gareth.
Try posting a picture of the problem - that will save you having to explain it...
^^^^ +1
Am betting the orignal was Stream / Stream MP3 or Bolero. ;)
Does it look like this:
Bingo that's exactly how it looks yes,it looks awfull is there a part I can buy to fill the gap,thanks for putting up the photo it's very good of you.
You'll need to buy the whole trim. There's no "filler" parts. Unfortunately I only have the numbers for a pre-facelift. I know the climatronic controls are a different shape.
I ordered one for mine, cost just over a fiver. :) :)
Did you order direct from skoda if not do you have a web address for where you got it fom,cheers Gareth.
I got mine direct from the local Skida dealer for less than £5. It was for a Columbus though, but can't see the price being much different.
Mine's from a dealer too. I don't think there's a "Columbus" one as such. There's the Stream/Bolero one, and the "other" one (fits everything else).
After that the variations are:
Pre-FL or FL
Climatronic or (whatever they call the non-climate control)
Colour (black or aluminium)
If you have a dealer close by, give their parts dept a squeeze and see what they say.
Thanks for all your help,I'll nip to the dealer tomorrow.soon as I get it done I'll put a pic on once again thanks all fo the help.gareth.
No problem.
Post the part number and price as well and make sure your picture shows the air con controls you have so that others in the same situation can benefit form your experience.
Thanks.
I got this one for my 2007 Elegance (pre facelift) with climatronic to fit round the RCD310.
1Z0 858 069 C 9B9 - Trim for climatronic switch for vehicles with navigation system satin black - no phone slot
The difference in part number should be the second letter (in my case C).
