Parking aid
Does anybody know if the warning signal volume on the parking aid(rear sensors) can be turned up as we can hardly hear it. Can't find it in the instruction book
Try turning the stereo volume up when it beeps, it works for sat nav
Thanks - tried that - all it does is turn the radio up
Have you tried this
Refer to section 3 of your Funky radio booklet, volume controls.
Press MENU on the radio then press SET that's the furthest right of the push buttons. Then press the PDC button (Park Distance Control) then make a selection of what volume you want. Apparently you need to have the PDC active for this operation.
I don't have reverse sensors (PDC) so unsure but do you need your PID unit in use for this function or does it just work without it connected?
If the above I had a problem with the PID unit volume control on the sat nav function, I couldn't hear the voice commands through the speakers, it was very low. I reset the unit which then allowed me to access the volume control function. If all else fails you could try this.
Mick
Have you tried it with the Radio off and the PID on?
