Headlight adjustment
Had the new one out in the dark for first time, aren't bi-xenons just the m*tts n*ts (at least when adjusted properly).
Found them slightly out of alignment for normal driving, but ok if I was lamping for pheasants !!
Found 3 adjusters on each side, most obvious one at the top for vertical hold, so got that sorted, but still need to pull nearside one a bit to the left, make it less divergent.
Twiddling the other two adjusters didn't make any difference at all, can anyone point me in the right direction (which is what I'm trying to do with the lights!)? Maybe I'm not twiddling enough.
Cheers the noo.
If you are running HID's I think there is a special way to adjust them, not just twiddling the knobs, that involves electronically setting them to "test" or something similar mode.
