Driver side wet mats
Noticed wet floor mats but cudnt find the origin.last day I found after driving for about 2hrs water dripping from the brake pedal/accelarator area!! Where do u think the water comin from?
Had a replacement screen at any time ?
Paul
My rear washer piping leaks somewhere up above the accelerator/break peddles :wonder:
Yeah the windscreen was replaced once but that's like 5 yrs before..dampness came recently...
Once there was dampness due to blocked sunroof drainage..I checked all drains they all work perfectly!
I think it's the AC water leaking but which pipe?
My car doesn't have a rear washer!!
it could be leaking out of the evaporator I guess, in which case check the drains from the a/c system. This drains out under the car so you'll have to get underneath to check that its not blocked.
I can see water dripping under the car after I stop..don't know if there is aleak on that hose? Gotta give to dealer for checkup
