air condition not cooling and air fan not work
octavia 2009 MPi-1600cc
I found my air condition not cooling also the fan not work cold or hot although the lamps are lighting
I checked fuses of a c there are 2 fuses in cabin they are very good
I checked the compressor during engine running it is ok but not latching when ac on.
so please i want to know the reason of these problems and if these are electrical link between fan blower resister and the compressor
also please tell me the location of pollen filter , fan blower and the resister &how can i solve my problems
than you every body
Posted in the wrong section mate... But a good place to start would be checking the voltage at the heater fan which is behind the glove box, you should be able to check at the connector just by taking out the foam trim up under the dash.
