Fitting Symphony head unit into older Octy?
Can anyone confirm if a Symphony head unit from the Octy VRS will fit into a '99 Octy using the standard loom or if I will need to re-wire at all? Has anyone done this in the past found any issues at all or does it as I hope just plug in :)
thanks
Andy
Bump....
Anyone know if this is an easy job?
thanks
Should imagine it would work with the standard loom.
If this is any use, I've attached a pin diagram of the rear of the headunit - if you look at the existing loom, you might be able to figure out if matches up... :)
Rob.
4471.attach
