advice needed......
hiya peeps.
quick one for you today.lol.
i want to get the "flick" type key that you find with most VWs and audis, and i believe on VRS? can your tell me what frequency it says on your VRS key fob?
as i think on my seat ibiza it is 433mhz.
i assume the alarms systems and immobilisers are the same?
reason i ask is that there are some 433 mhz and some 434 mhz fobs in the VAG range.
anyone with some advice on this?
thanks in advance
I have a Fabia vRS (05) and I've looked all over both fobs, and the key numbers and can't find a frequency anywhere. Sorry! :o
433 MHZ
I've supplied and programmmed two flick keys and remotes for Tom (toxxin) before and both were bought from SEAT.
They work out around
thanks anyway peeps,
thought i could get away with taking my chance on ebay and buying acheap one..worth a try?
You could get a remote but would still have to key the key cut.
i think i migt, but from what ive seen, most vw fobs on ebay are 434 mhz..so it wouldnt work would it?
no
434MHz is a PMR band allocation in the UK (police radios etc.), so not only would the fob not work, you could technically end up before the Beak for using it, I think. The UK ones are 433MHz as this is a 'free' band for short-range radio...
I'd avoid ebay on this occasion!
  • 1 year later...
I know that this reply is inordinately late, but one of my skoda keys, has a green disk under the battery which amongst other data proclaims 434 MHz.
