Clutch Plate N Fly Wheel Assembly
Hi from few days have noticed d clutch pedal of ma laura has gone hard n one fourth dead have covered 61000 Km so far a mth back d Slave n master cylinder had gave up got replaced n d technicians said cars fly wheel has gone loose n clutch plate has To b replaced however i dont find any drop in power but yes clutch is Too hard to use specially in Mumbai traffic dont know what should b done guyz ny suggestion of go with replacement??
Also ders sort of sound wen driven at low geats at low speeds like gurrrr sort off..
When engine idling also ders some kind of noise like dug dug
Not sure whats all bout showed d service rep said dug dub is usual
Ny suggestions????
Thanks Mike for ur reply mine is a Diesel Oil Burner 1.9 Pumpe Duse Octavia II version the noise is not Too high nor but could be heared if listen carefully like dhuk dhuk may be you are correct as the service guy did say Fly Wheel N Clutch assembly need a replacement however also mentioned keep using till it goes on..
  • 4 months later...
Hi all
I have skoda Octavia vrs 2005 petrol
I have pickup issue
N hard clutch issue
N chirping sound
I need to replace clutch plate n pressure plate n clutch bearing ??
Pls guide me
  • 7 months later...
Yes, I do think that you need to change the whole assembly except the flywheel.
Basically, chirping sound(if coming when releasing the clutch) means a worn out release bearing.
Pickup issue would mean worn out clutch plate,with which, it would be a good idea to replace pressure plate as well.
Not sure abt the flywheel though.
