running in a 1.2tsi, which way is right?
What is the correct way to run one in? Heard so many different opinions, some say keep belowa certain rpm some say you don't need to run them in at all?
Just drive as you normally would, that is the manufacturers recommendation.
I would run it in by letting the tyres scrub in a bit, getting the coating off the discs with some light usage which will start off the brake pads well without too much hard braking..
The engine & drivetrain will be fine while you are just getting used to the car.
Just take it easyish for a few hundred miles.
(like it says in the Owners Manual.)
Check the tyre pressures and set them yourself when you get the car.
Enjoy its newness.
have fun.
george
We were careful for 600 miles, then revved it a bit for the next 600, then just used it as normal.
I do almost redline it once every 500 miles. Because I know my wife drives it too slowly.
Yeti, but same engine.
As George says, let hte tyres and brakes bed in during the first stage while going a little bit easy.
He is right on the tyre pressures too.
They are not always correct on new cars and people just don't bother.
Bit of a long read, but here's what the owner's manual says about running them in:
The first 1 500 kilometres and then afterwards
The engine has to be run in during the first 1 500 kilometres.
Up to 1 000 kilometres:
– Do not drive faster than 3/4 of the maximum speed of the gear in use,
that is 3/4 of the maximum permissible engine speed.
– Do not use full throttle.
– Avoid high engine revolutions.
– Do not tow a trailer.
From 1 000 up to 1 500 kilometres:
– Increase the power output of the engine gradually up to the full
speed of the gear engaged, that is up to the maximum permissible
engine revolutions.
During the first operating hours the engine has higher internal friction than later
until all of the moving parts have harmonized. The driving style which you adopt
during the first approx.1 500 kilometres plays a decisive part in the success of
running in your vehicle.
You should not drive at unnecessarily high engine revolutions even after the
running-in period is complete. The maximum permissible engine speed is marked
by the beginning of the red zone on the scale of the revolutions counter. Shift up
into the next higher gear on a vehicle fitted with manual gearbox before the red
zone is reached. During acceleration (depressing the accelerator) exceptionally
high engine speeds are automatically reduced, yet the engine is not protected
against too high engine speeds which are caused by incorrectly shifting down the
gears resulting in a sudden increase of the engine speeds above the permitted
maximum revolutions which can lead to engine damage.
For a vehicle fitted with a manual gearbox the converse situation also applies: Do
not drive at engine revolutions which are too low. Shift down as soon as the engine
is no longer running smoothly.
Caution
All the speed and engine revolution figures apply only when the engine is at its
normal operating temperature. Never rev up an engine which is cold, neither when
the vehicle is stationary nor when driving in individual gears.
For the sake of the environment
Not driving at unnecessarily high engine revolutions and shifting to a higher gear as
early as possible are ways to minimise fuel consumption, operating noise levels as
well as protects the environment and contributes to a longer life and reliability of
the engine.
New tyres
New tyres have to be “run in” since they do not offer optimal grip at first. You should
take account of this fact for the first 500 kilometres and drive particularly carefully.
New brake pads
Allow for the fact that new brake pads do not achieve their full braking efficiency
until approximately 200 kilometres. New brake pads must be first “run in” before
they develop their optimal friction force. You can, however, compensate for this
slightly reduced braking force by increasing the pressure on the brake pedal.
This guideline also applies to any new brake pads installed at a future date.
During the running-in period, you should avoid excessive stresses on the brakes.
This includes, for example, violent braking, particularly from very high speeds, and
also when crossing mountain passes.
