Bora tdi in sdi wireing
Turns out the ecu connection for the body of the sdi is different to the boras.
So does anyone have a pin out for the ecu connections of a 2002 sdi? And a if poss a 1999 tdi bora (afn) lmao
i have autodata disc, but it wont let me copy n paste the info. if you tell me exactly what you want to know, i might be able to help.
Right i need to rewire my octy to the bora plug so i can use the tdi ecu.
Ill need a list of what color does what for each of the ecu body connections
ok, it will take me a while to collate the info. please be patient, and i will get back to you asap.
1.pdf
try this. as far as i can see, they are both wired the same way.
Cheers man thatll help been keeping myself busy ordering stuff lmao and sorting bits on the disco.
Gonna delete the air con in the conversion im looking for the non ac alloy aux bracke partt number if anyone has it to hand i cant seem to find it. So been looking at a mk4 golf unit which im hazarding a guess will be right.
