Flywheel Bolts confused
Finally get my clutch fitted this Saturday (19th) mechanic guy has said to get new bolts.
I've been told there is two types of bolts for two different clutches LUK and Sachs
These
Then these..
Could someone with ETKA or someone who has replaced the clutch in the TFSI help me out it would be gratefully received.
If the worst come to the worst, could you not get both types on the understanding that you only need the one, and will return the other. I presume you are getting from VAG
The bolts in the 2nd picture are what you need when replacing the stock differential with an LSD that's for sure, but I'm unsure if they're also used in the clutch assembly. Doesn't really help you much, does it?
its cool Harry, turns out its the first pic i need, ordered them and rear pads from ECP
