Apple Ipod
So are you planning on going for an aftermarket HU too Phil?
Rob.
  • Replies 89
  • Views 9.5k
Not at the moment -the Omega has a double din housing, and the standard one ain't bad. -Though I'm still trying to get hold of a 10-speaker Bose system, as fitted to the Elite models! Not many Omega's get scrapped, so there aren't many about -though I've got my Vauxhall contacts looking out for me........
Phil
So how are you getting the output from the MStation to the speakers? FM modulation/cassette whasit?
Rob.
Initiall, via the FM mod -my car has a rear screen antenna, so I can get to the aerial connection easily, near where I'm fitting the unit, in the boot. I'll run a couple of RCA's with the remote cable, though, so I can use a cassette adaptor if I want to -but I don't like the way they look. I'll see how the modulator goes.
Phil
Tell us how it goes, might save some people time and money with not buying new HUs... ;)
Rob.
Maybe, although if you had a long lost cousin's friend of a friend in the US who could ship one over by way of a 'birthday gift' you might still be in luck!
Does anyone know what type of connector the AUX-in is for a car HU.By this I mean are they all of one type (RCA etc) or does it vary by manufacturer?
The reason I ask is that I have to order up a cable from my iPOD 3.5mm headphone socket to link up with my new HU via the AUX-in terminal.The only problem being is I have not received my new HU by post yet so not sure which would be the correct connector and therefore which cable is suitable.
Hope all that made sence and once again, apologies if this is another stoopid question...................................
Cheers
Hugh
If it's front mounted, it's normally a 3.5mm stereo jack. rear mounts tend to be phono connectors -but there do seem to be some weird non-standard items around, too.
Phil
Cheers Phil,I think I may just have to be patient then. I'll wait for the HU to turn up and then order the correct cable from what I find at the back of the unit.
Cheers
Hugh
Agree with Phil on this, it could be anything - you're best waiting for the unit to arrive (unfortunately!).
So if that iTrip is illegal because it broadcasts an FM signal, what about those CD changers for standard headunits that work by FM modulation?
Rob.
FM modulation is not illegal, just the wireless transmission of these signals. The keyword is wireless.
Doesn't the I-File use FM modulation, or did I totally miss the point on that one? :)
Rob.
The iTrip uses FM modulation, but then continues to broadcast it into the ether, unlike the FM modulator that comes for instance with my mStation. That just inserts the sound onto the aerial lead to which you can tune the HU too.
Oh...right, I get you now...I thought FM modulation worked around the same principle as the I-Trip! Everyday's a school day! :D
So how do you find the quality of the sound coming from the mStation using FM modulation?
Rob.
Rob, haven't even powered up the mStation yet :D I've got all the parts needed to install it in the car (and won't be using FM modulation as everyone will agree it is crap), just finding time is a bit hard.
Hi All,
Just a note to say many thanks to all for the advice and help given to me concerning my ICE upgrade.I'm not too bad with home hi-fi, I was however, a complete ICE novice but with the help given here I installed it at the weekend without much hassle (well, except one of the original HU's locating clips getting mangled when trying to remove it!).
The results are tremendous and it's great actually being able to LISTEN to the music again without the feeling that someone was standing with a pillow over the speakers! If anyone is interested I can get some photo's and post them on here to show the full install.
Cheers
Hugh
Of course we're interested - get those pictures on! :)
Rob.
Will do, will try to get them done toight.
Cheers
Hugh
or 'tonight' for those that can spell!!!
As promised, here are some photo's of my ICE install.Not sure if they will work but here goes..........:D
Cheers
Hugh
372.attach
Cheers
Hugh
373.attach
Neat looking install - didn't realise how small the I-pod is!
I hope that's held in place with a nice big strip of velcro... :D
Rob.
Thanks Rob,apologies for the **** pictures as I was using SWMBO's iMAC (excuses,excuses!).
Velcro..............what a discovery,eh??!! lol
Cheers
Hugh
Forgot to add that I have a new problem,passenger front door speaker now rattling!It was doing this prior to the HU change so I don't believe it has anything to do with that but I'm a bit hacked off as the system is now sounding pretty good.
Will try to investigate further tonight but hope it is not a dodgy speaker.............
Cheers
Hugh
