Octavia Vrs front 12v point not working
Hi for some reason my front 12v point on the dash isn't working can any one help as I don't know which fuse to change
Have you tried pressing the switch to deactivate the rear window switches as this also apparently deactivates the 12v socket (unless you have a factory fitted front arm rest).
Hi thanks just tried and the deactivation button for windows doesn't work either must be a fuse as windows work when button is in both position any idea what fuse is for them
I dropped a 5p in mine and it fused easily done
Essexocty do u know which fuse to change
The one that's blown. Have a look, 15 rings a bell.
It's in the handbook or on the back of the fuse cover if its still got the card tucked in there.
Ok I'll take a look thanks
An checked fuse 15 and it was for the light inside car and can't find handbook :(
Can any one check there's pleaseeeeeee
Fuse 41 - 15A in main fuse box
Thanks kentphil1
Yeah ill second that
