I have 2 Yeti 2.0 TDi 4x4 - one bought in UK, other in France. Lighting programmes vary between the two. On French vehicle under 40km/h at night, the front 'spot' lights become corner turning lights. Great on the rough roads on the French garrigue, at night. But my UK Yeti won't do this! Living in the country in the UK, I wish my car could dobwhat the French one can do, as it makes corners on narrow roads much safer. The Citroën DS did this trick with moving, mechanical turning lamps, I believe. Skoda system much better with software control and focused beam from fixed lamp. Why is this feature disabled for UK cars - or may there be a way to use this feature on a U K car?
Hi and welcome aboard.
Hi,
It really depends on what spec Yeti your UK one is, only Elegance has the lighting you speak of as standard fit as far as I know! Welcome to the forum :)
Standard fit on ours too, but they are also Elegances.
Some models do not have the cornering light feature, it's dependent on what spec level you bought.
