Speaker wires, please look want to finish today :)
Which of these wires do i need to keep for the rear speakers?
wires
Im putting some alpine e types in, currently there are 6x9s which are attached to the plug on the spurs.
But do i need both sets as only one was plugged in when i looked before, plugged the other in for the pic.
I would prefer to cut the plug of and use connectors straight to speaker, but do i need all 4 wires or just 2 as in use at the mo!
Probably over complicated that but hopefully someone knows as wanted to get these done today as already done one front one :)
One of the plugs is just a feed from the woofer to the door tweeters. So it depends on how you're installing and what.
Cut and strip back all 4
Carefully, at v.low volume, work out which are the direct feed and which are the through/repeater/daisy chain
Crimp blade (or whatever connector is required) onto active pair wires
The rear door tweeters are in a duff location, so best disconnected
ah ok didnt realise there were rear door tweeter!
Put coaxials in so best disconnected then!
Thanks for response :)
