engine management light
HI
After a recent wee shunt where i hit a high kerb when reversing car , and ended up jerking front bumper free from a few screws
I noticed that exhaust smoke was a lot blacker, and a bit of stuttering, and finally engine management light came on,
After an inspection of that area i found that bottom mounting had ripped free from inter cooler leaving a 5p sized hole in plastic casing
And air hissing from there. so on e bay i found a used one . and after a bit of B*******G about got it fitted started car no leaks ...HOORAY
Looked at dash engine management light still on?????. switched off car and turned ignition on all lights went out !
Except the engine management light, and i still hadnt started engine. do i need to go get it reset ?? or would disconnecting battery do it ?
Or knowing my luck prob something else wrong
Car is a superb 1.9td 2007 bpz engine type
I think EML goes out after 5 restarts once the problem has been cleared.
Have you had the car scanned or are you just assuming it was the intercooler putting the EML on?
U
Up till now just assuming that big hole in intercooler casing was causing EML to come on
As it only came on after the accident , and can see no other apparent faults
But if it stays on i will have to have it scanned
Edited by garytaxi50
