Alloy wheel cleaner
Any one recommend a good cleaner to use on my alloys wheels? There in good condition but hard brake dust has gathered in the corner of some of the spokes and i need to remove it. Cheers
It's not so much of a specific Alloy Wheel Cleaner you need, it will be a combination of a few products......:(
If you have brake dust build up then more than likely you will need some Iron-X to break this down followed by some AS Tardis to break down any tar deposits........:)
Best to use both of the above products after you have cleaned the wheel as best as possible with a generic wheel cleaner or APC product...........:)
It's not so much of a specific Alloy Wheel Cleaner you need, it will be a combination of a few products...... :(
If you have brake dust build up then more than likely you will need some Iron-X to break this down followed by some AS Tardis to break down any tar deposits........ :)
Best to use both of the above products after you have cleaned the wheel as best as possible with a generic wheel cleaner or APC product........... :)
What he said! :thumbup:
