Ccu problems vrs
Had problems with the locking and the windows on my vrs. Figured it would be the CCU in the door, i was correct. Was full of water. Anyway sorted it out the windows work, the passenger door lock isnt constantly clicking and the doors lock/unlock all apart from the drivers door. The pin, i assume for the drivers lock fell out the ccu when i removed the plug :(
Any suggestions? Apart from replacing the ccu? Also if it needs replacing does it matter that my car has a sunroof? I assume its linked.
Sent from my iPhone 4s
How much of the pin has brocken off - any chance you got a stump left on the CCU ?
Theres a tiny stump left but its minimal. Because im a bodge artist im thinking i could get a pin and jam it in the connector and hope it makes enough contact to work maybe
That's what I've done in the past
Alot depends on size of pins and what you have to hand that might fit down offending pin-hole
Bet its too small for a tiny chunk of silver foil
the ccu is not in the door, that is the drivers door control unit which interfaces with all the controls on the door unit to do locking etc etc
get it scanned first to see if the ccu has been goosed - it is under the steering wheel and costs ££££ if knackered
Well the unit in the door is the offending item. I will try a bodge in the next few days to see if it will work.
Anyone know the best place to buy electrical pins
RS components or Maplins
thats the door motor mechanism by the sound of it, you can get the microswitch from maplin, but for the effort a pattern part can be had for £40, might be an easier option
What i did with mine, when it went kaput, was to remove all the yellow sealing gunge from around the pins, then strip open the control box thingy, trace which pin had snapped off, solder a length of wire to the good side of the broken pin, drill a tiny hole to pass the wire through, then splice the wire into the multi plug harness. Bish Bash Bosh... Jobs a good un!
King of bodges.
Going to pull it apart tomorrow weather permitting and see what i can do with it.
Similar problem with mine. Drivers door doesnt lock/unlock with remote. Only does with key. And drivers side electric wing mirror doesnt work...
