Air quality sensor
Anyone know how these work, as am getting an error on vcds which suggests its a wiring fault but have checked that. Wondering how to test the sensor itself.
It's a 3 pin setup, switched live, ground and signal. Does the sensor divert a voltage down the signal wire on detecting noxious air?? As if so I can eliminate the wiring by connecting live to signal.
Adam
Anyone have any idea pls?
Ta
Adam
  • 2 years later...
HI Briskodian, Did you fix this problem? I have the same problem, Thanks
Pretty sure they weren't fitted with one and it's a coding issue.
In my case I did fit one, but I fitted it incorrectly, mixing up the positive and negative pins on the climatronic switch panel.  I reversed the pins and wires and all was fine.
